‎2007-11-07
07:53 AM
‎2023-05-23
05:04 PM
Rubia Torres
‎2007-11-07 10:11 PM
‎2007-11-07 10:46 PM
I've a SEO question, is in what condition or element can be use SEO?
I've try subtract a sphere(object) to a slab,it's work but when I try a bottle(object) to cut the slab, it's not work, Is that bottle too complex??
Some library parts may not be true solids. That could be the case with your bottle.
‎2007-11-07 11:41 PM
Scrat wrote:Just using ArchiCAD's Solid Element Operations (SEOs). The complexity of the bottle object is definitely a factor in the success of this tool. When my bottle object was set very smooth, an attempt to use it as an operator against the slab was unsuccessful. It sat there for a long time (with spinning cursor), and the slab remained unchanged when it finished. Pushing the bottle smoothness down resulted in the image you see and finished reasonably quickly.
How do you do that?
‎2007-11-08 09:42 PM
‎2007-11-08 11:42 PM
Scrat wrote:The bottle shapes were made by drawing half their cross-section with the polyline tool and creating a lathe profile with OBJECTiVE. I drew two different profiles because I wasn't sure which case the original question referred to (see the attached image). One profile creates a solid blob, the other is hollow inside (as a real bottle would be). The effect with SEOs is quite different in each case, but the critical step was to make sure the objects weren't too smooth (the SEO would fail).
I know how to make object but what was asking is how do you create that ball-shape part (top of the bottle).
And how do you usually create a ball
‎2007-11-08 11:58 PM
‎2007-11-09 12:09 AM
Peter wrote:I don't know - I haven't used Profiler for a long time because the objects it produced were a bit crude. I usually want to rotate and/or cut up the objects I make, which I don't believe Profiler supports. OBJECTiVE components also have a built-in smoothness setting.
Hello Ralph,
Would you agree that, in case someone does not have Objective,
the exact same procedure as you describe works with
Archicad's Profiler using the revolve construction method ?
‎2007-11-09 01:45 AM
‎2007-11-09 03:54 AM
‎2007-11-09 04:48 AM
