6 hours ago - last edited 6 hours ago by Barry Kelly
Hi! as the title says, I regularly need to use custom openings directly in elevation. But that setting is not available (is grayed out) also in floor plan...?
but it is grayed out! I intended to do hole in the slab/box for fireplace or niches in the wall (very simple)
Any solution to it or it is not suppose to work in interior elevation for some reason?
Your image shows that the irregular shaped polygon input method is active.
You just need to draw the shape.
Or do I misunderstand what you want?
