2022-05-31 08:52 AM
I can't modify Edge beam strip footing profile dimensions (or "Modifier" parameters).
I want to create copy & modify the "Outer Edge Offset" distance .
please see attached.
Or should I create a new profile from scratch?
Solved! Go to Solution.
2022-05-31 09:25 AM
To adjust the dimension, select the fill and offset the edge of the polygon.
The modifiers in the Profile are the defaults, and these can be modified when used on an element (Wall, Beam or Column). But if you want to modify the defaults, then you just need to modify the fills shapes.
2022-05-31 09:25 AM
2022-05-31 03:19 PM
Great. Thanks James.
That was not at all obvious.
2022-05-31 03:20 PM
Sorry, I meant to accept your post as "Accept Solution"
