2022-08-28 11:55 AM
This I'm guessing is a common problem,
But - I've changed the home storey of a wall, by creating a lower level (NGL) and setting ext walls that.
But I can't see the walls on FL level?
I've changed the "Floor Plan cut Plan Settings" to 1 level above, but it doesn't help.
If I change the wall home storey back to FL I can see the walls again (Please see attached - I've highlighted the wall so you know it's there).
2022-08-28 12:10 PM
Have you tried changing the view options of the wall to be symbolic cut or projected or projected with overhead to see what affect that has?
2022-08-28 02:34 PM - edited 2022-08-28 02:36 PM
Hi @cadsph, @Lee Hankins, I see you should set the wall linked to NGL FL from below and Roof FL from above while setting show on floor plan to All relevant stories & keeping Home story to FL.
2022-08-28 03:00 PM - edited 2022-08-28 03:04 PM
Thanks for your post.
No It's makes no difference, I can't select Symbolic Cut - it's whited out.
2022-08-28 03:03 PM
Yes. That works.
But, I should be able to see a wall linked to a lower level visible in an upper level, is more my question.
Say I have a 2x storey house and the walls continue to the upper level?
2022-08-28 03:11 PM
So I understand you like to see the wall in FL floor only, is it right?
So make it linked to FL & ROOF floors keeping home story to FL,
change Show on floor plan to home story only and adjust the wall base to extend below the FL floor by +0.60 m.
2022-08-29 12:26 AM
cadsph,
In Archicad, it is generally not recommended to create such non-Story levels as they can cause all kinds of issues like this one. I know that in Revit, one can create any number of levels and set them to be or not be a Building Story level, but Archicad is not good at handling such scenarios.
2022-08-29 01:17 AM
Thank-you all for your posts.
I solved the problem. The walls were hidden under the slab. I just send the slab to the back...
(while keeping the home storey of the walls to NGL - I can see the walls on FL)
2022-08-29 01:21 AM
No exactly- I wanted to have the walls home storey on NGL (Level) and see the walls on the FL (Level). I was just puzzled why I could not do that.
But as I posted - the Slab was in the way.
But you are correct- your method would work also.
2022-08-29 01:22 AM
Thanks for the tip.
