Can't select drawings in Layout
I can not select drawings in my Layout.
If I use Ctrl-A I can select all but I can not hold down the shift key and deselect items either.
Any ideas about why this is happening?
6 REPLIES 6
Is the grid snap on?
yes.
Thank you.
Even the veteran members still fall for that one!
Maybe the Layout space should have a disclaimer...
Not my first time to have this happen either.
Eeven though the snap grid was off for drawings, Layout has a separate setting and memory for that.
Haneef Tayob
Incidently the grid snap toggles when the 's' key is erroneously pressed (ie its shortcut).
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Eduardo Rolon
That is why one of the first things I teach and do is to map the "S" key to the slab tool.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
