Can't stretch 2D objects freely
Sakha
So, my Archicad can't stretch objects other than multiples of 50, but only for the project I'm working on; in new projects, it's no problem. How do I fix this?
2 ACCEPTED SOLUTIONS
CosminF
hi,
You may have accidentally enabled grid snapping (with Alt-S) ? Try seeing if you have something enabled here:
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
check the snap grid.
AC 28 INT 3110/WIN 11
CosminF
hi,
Sakha
thank you, this community is really good, bless you all 👍
