Cannot access project folder
New problem with Teamwork. I am trying to sign into a project located on our server, but the project folder along with several other folders are showing up greyed out and I cannot acces these folders. When going through the finder window I can access all of the files and folders, just not through the sign-in window. As far as I can tell all of the permissions are the same for all of the folders, so I don't think it is a permissions issue, but I cannot think of what it can be.
Edit: OK, the only thing I could come up with was I was on the new build and others were not. I have since re-installed build 2045 and was able acess the folders.
4 REPLIES 4
I have verified that this is some kind of a bug. I reverted back to build 2045 on my office desktop and it works fine. However I installed the update on my laptop and I get the same greyed out files when networked to the server.
I checked and the problem also occurs in the open dialouge box from Archicad and Plotmaker. Even when the file type is set to "All files"
Graphisoft found the problem. Embarassed that I had not pinpointed it myself. File and folder names cannot exceed 31 characters. In previous builds this evidently caused problems, but still allowed access to the files. In this new build the program just greys out the files.
Djordje
They should be embarrased that 28+3 is still alive and well ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
