2022-11-24 11:47 PM
Hi All,
In Archicad25 you could go into surfaces and remove the associated image missing to a certain texture but now in Archicad26 this delete option is greyed out?
2022-11-25 01:09 AM - edited 2022-11-25 01:10 AM
Hi Scotty,
You manage the texture image files with the small upper right icons. You can add or delete there. (Air Space does not have a texture associated, hence it's typically blank.)
2022-11-25 01:12 AM
Try adding any other texture and then delete it.
