2014-01-2210:37 PM - last edited on 2023-05-2504:48 PM by Rubia Torres
Is there a way to make a cantilevered stair in archicad using stairmaker?...or another tool?... I can make them using slabs and modeling everything manually so to speak, but it looks like such a simple type of stair (shape wise) that is surprises me stairmaker doesn't have it as an option.
I'm not sure if Cantilevered is the correct name, the stair I'm refereing to is this
Another option is to draw the longitudinal section of the Stair in the Profile Manager's Editor, save it as a Profile and place it. Possibly as a Beam because then you will have less problems with it intersecting with other element as might be the case with a Wall.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
well, you can do it with Stairmaker, with a little trick.
The down side is the fact that you get those tread / risers unnecessary lines.
My 2 cents
Nando Mogollon Director @ BuilDigital nando@buildigital.com.au Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes) More and more... IFC.js, IFCOpenShell All things Solibri and BIMCollab
