Casings showing in wall when turned off
Why haven't the casing issues been resolved yet?
1. that when you turn the casings off they still show in elevation and still cut the siding when shown in a stud wall with siding.
2. changing the width of casing makes it grow larger to the inside of the window not the outside.
These two things make ArchiCAD windows basically useless, and I think this is unacceptable. . . It is driving me nuts here.
You can't just send out expensive software that doesn't work, especially when this isn't a new function, it worked in previous versions.
the AC12 doors and windows are a mess, even after the 1st library update. I agree it is totally unacceptable, but that doesn't help me in my day to day operation. My solution has been to revert to v11 door and windows.
Yes, reverting to 11 doors and windows works, but once v.13 come out imagine the mess that's going to cause using those doors and windows, or trying to use a migration library through 2 versions.
