Tom Krowka
Casting shadows with open GL
Can I set up AC to cast shadows on a model using a VR object. Using Open GL engine, VQTR2.0 engine. All the choices are greyed out.
Tom Krowka Architect
Windows 11, AC Version 26
[email protected]
www.walshkrowka.com
17 Replies 17
Link
No shadows in OpenGL, Tom! No semi-transparency either!
Link.
Tom Krowka
Any other way to do it within AC?
[email protected]
www.walshkrowka.com
Link
Sure!
Check the Photorendering Window when you create your VR after making sure shadow casting is turned on in Photorendering Settings!
Link.
Tom Krowka
Photorendering is sooo slooooooooooow. Any tricks to speed it up? I've tried it with a .jpg background of clouds, etc. I would suppose that slows it down a lot.
[email protected]
www.walshkrowka.com
David Pacifico
Tom
A background image isn't going to slow it down. In fact it can be used to speed things up. See Links Tip. http://www.graphisoft.com/support/archicad/archiguide/QuickRenderTip.html
Be sure to turn off High Accuracy for Sun Shadows. Come to think of it can you live with out Shadows? Probally not. Can you turn off Lamps and or Lamp Sun Shadows? After that the next biggest time effect might be Antialising. You might ease that back to "better". (Use "good" for an animation.) The Method I would leave on "best". I don't find any time penalty there.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Djordje
Go to www.abvent.com and download AV Works. Enjoy.
Nope. David P already explained it.
Your computer specs also add up to the equation, especially processor speed.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
aahatimo
Link.
any idea why we have no open gl shadows?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Ralph Wessel
Standard OpenGL doesn't calculate cast shadows.
Ralph Wessel BArch
Central Innovation
aahatimo
thanks ralph, learning something new every day.
tim hanagan
