Change 3D Mouse Movement?
When I'm in 3D explore mode, I want to look at the ground when I move the mouse forward, and look at the sky when I pull back -- exactly the opposite of what it does by default. Is there any way to change that?
1 Reply 1
__archiben
move the mouse forward or backwards to look up or down whilst moving with the keys (W + S). hit F to turn 'fly' on and off so that your height doesn't change . . .
~/archiben
b e n _ f r o s t
