‎2008-04-2501:27 PM - last edited on ‎2023-05-2602:49 PM by Rubia Torres
‎2008-04-2501:27 PM
Hi
I would like to know if it's possible in AC to change the fill settings/display of various construction elements in a 3d window generated with marquee tool. They all appear black in my views, with no distinction between these elements.
Under the command "3D Cutting Planes...", there are options for Fill Material & Edge Pen of Cuts, you can choose "Custom", which uses one material for all the cuts, or "Use Element Attributes". You may need to rebuild the 3D Window after changing these options in the dialog box to get the selected results.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro OSX14 | 36 gb ram
