Change Fill Display in 3d Window Generated with marquee tool
Hi
I would like to know if it's possible in AC to change the fill settings/display of various construction elements in a 3d window generated with marquee tool. They all appear black in my views, with no distinction between these elements.
Thanks
1 REPLY 1
David Maudlin
Roberto:
Under the command "3D Cutting Planes...", there are options for Fill Material & Edge Pen of Cuts, you can choose "Custom", which uses one material for all the cuts, or "Use Element Attributes". You may need to rebuild the 3D Window after changing these options in the dialog box to get the selected results.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
