Change SEO operation type after executing
Scott Deisher
I have created a solid element operation and executed it using "Subtraction." I would like to modify that operation type to instead be "Subtraction with upward extrusion." Is there a way for me to change the operation type without redoing my operator/target setup process?
2023 M2 Max Macbook Pro
Sonoma 14.5
ArchiCAD 27
4 REPLIES 4
Unfortunately, no.
David O
Hi yes you can just select the cutter object & set it as the operator again, select the object to be cut and set it as the target then change the subtraction option to subtract with upward extrusion & execute it.
Regards
David
Regards
David
Isn't that just re-doing the operation?
Sure, you don't have to cancel the original SEO, but you do have to re-do it.
You can't just swap as the original poster wanted.
Yes your quite right but it does reduce the cancellation step which is half way there
