Change everything to new renovation state
Strawbale23
Hi
Is there a way to select everything in the project and change all elements together to a new renovation status?
At the moment I select everything but only certain elements actualy change status. I have to keep selecting and changing.
Is there not a way to just select everything and have them all change together?
Thanks
AC26
https://www.zendsign.fr/
Go to the Document Menu and then the Renovation Menu and there should be an option somewhere in there to reset the renovation status. You can choose from drop downs what to do with each set of elements which are currently on each filter.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
Lee Hankins
