yesterday
I’ve tried to change the width of this staircase landing using that pop-up menu (the blue one), and I thought it just dragging it to the right, but it doesn’t seem to be working. Is there a way around this? Thank you
Operating system used: Windows 25H2
Solved! Go to Solution.
yesterday - last edited yesterday
Alternative method for the selection of the Stair Boundary:
4 hours ago
Thank you very much, sir. I had assumed that this was a limitation of the app, as I couldn’t find a solution on YouTube either, but now I see that isn’t the case. I do hope there will be an update on this stair tool
