yesterday
I’ve tried to change the width of this staircase landing using that pop-up menu (the blue one), and I thought it just dragging it to the right, but it doesn’t seem to be working. Is there a way around this? Thank you
Operating system used: Windows 25H2
Solved! Go to Solution.
yesterday - last edited yesterday
Alternative method for the selection of the Stair Boundary:
21 hours ago
Thank you very much, sir. I had assumed that this was a limitation of the app, as I couldn’t find a solution on YouTube either, but now I see that isn’t the case. I do hope there will be an update on this stair tool
5 hours ago
The following 10-minute video clip from Graphisoft will give you a good overview of how to edit the Stair Baseline and Boundaries:
The clip is actually part of a playlist that was published when the new Stair tool was released in Archicad 21. It may be worth going through the whole playlist if you want to learn more about the Stair tool:
https://www.youtube.com/playlist?list=PLnXY6vLUwlWWIb70Jj3kq1o4dY9ZVuEWh
