Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Quick Question, 1:1250 is a scale we use quite a lot. Is there any way to add this to the drop down list? I am redoing our office template so would be useful to add but not a problem if its not easy!
Cheers
Matt
Unfortunately this is not possible.
You can switch to this scale manually and then save View.
Then use the Views to switch to Viewpoints with this scale.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
