Changing multiple wall height in 3D window.
I just found out that when I select more than one wall in 3D window I lcan't stretch the height of those walls. Is that the bug, or loose of functionality. If the second one, this schould be corrected in next hotfix (otherwise just fixed).
10 Replies 10
Try changing the height in the Info box after selecting all the walls. Do all of them change now?
Gary Bley
Thanks Peter I must have missed this one. Hopefully next hotfix will solve this problem.
gbley: look to the post provided by Peter.
__archiben
this is fixed in the mactel build released yesterday . . . so the next intel/PPC hotfix should have it nailed too . . .
cheers
~/archiben
b e n _ f r o s t
Yes, it does!
Alan wrote:
Yes, it does!
no, it doesn't!!!
Djordje
archimax wrote:
Alan wrote:
Yes, it does!
no, it doesn't!!!
Grouping off?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje wrote:
Grouping off?
yes, grouping off
I've reinstalled archicad, updated it to v987 int full (at least it was written in help menu) but I still can't stretch multiple wall height in 3d. Stretch works only if those walls are on the same vertical plane
Djordje
Works over here ...
Djordje
HP Omen
