Circular morph not smooth
Dontknow
Hello,
I've been digging into the morph tool.
With a circular morph the shape is not smooth.
Is there setting to make it smooth?
Greetings
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
5 REPLIES 5
David Maudlin
Dontknow:
You can increase the number of faces (smoothness) by selecting the Morph and using the Modify Segmentation... command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dontknow
Found it.
The number of arc segments is greyed out.
ArchiCAD 25.
Dontknow
Disabling 'Double Segments' makes it smooth.
Thought it had to be 'number of arc segments'.
Solved!
ArchiCAD 25.
David Maudlin
To use the Number of Arc Segments, select just the Edge, not the entire Morph. Glad you were able to get the results you need.
David
Dontknow
Oke, thnx for that extra info.
ArchiCAD 25.
