Close open windows.
Tom Krowka
Anyone know of a way to close open windows, (plan and s/e, not casement and awning) quickly. If one works for a while, several windows will be tiled one behind the other. They will regenerate upon coming to the front, which can take a while. Any other way to close them besides the x in the upper right hand corner? Could save some time.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
8 REPLIES 8
Thomas Holm
I f you want to avoid multiple window chaos, there is a setting in Archicad to Always Open new views in a new window, which you can turn OFF!
On the Mac, Command-W will always close the foremost window, and Alt-Command-W will close all windows, but in Archicad, if you close the floorplan, it thinks you want to close the project file and prompts you to Save - remember to NOT Close without saving, or else you will lose all your work since the last save.
In Windows - I have no idea!
Thomas, would you happen to know where that setting is in AC9?
Thanks, Doug
Djordje
ALT F4 or click on the X in the upper right corner
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
vistasp
CTRL+W works to close the current window.
I'm not sure if I've set things up differently, but ALT+F4 closes ArchiCAD on my system.
CTRL+F4 on the other hand works like CTRL+W and closes only the current window (in floor plan view it tries to close the project as Thomas mentioned).
I find the latter much easier on the fingers.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Tom Krowka
Let's say I want to keep the current window open, but close the six windows behind it. It seems that if I go to another window, it will regenerate if I have aoutrebiuld on, which I usually do. Is there a way to turn each window off without getting to the X, if it is behind the current window.
Thomas@wkarchwk.com
www.walshkrowka.com
Thomas Holm
On the Mac you can close any window that has it's red close button visible - you just hover the cursor over the button and it turns red, then click, and this works even if the window is in the background and partially obscured by others.
On Windows, again I have no idea.
vistasp
Natively, Windows (XP at least) has no such feature. The TweakUI Powertoy from MS <http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx> has an Xmouse setting but changing focus also raises the background window - which will lead to a regeneration if you have turned on autorebuild.
There is a small free utility called True Xmouse which avoids this problem <http://fy.chalmers.se/~appro/nt/TXMouse/> but needs registry tweaking to work the way you want.
= v i s t a s p =
bT Square Peg
Link
I think you can achieve what you want by working with windows that aren't maximized. Even if you manually stretch the window to take up the most area available, you should be able to minimize the window(s) you're working on and close the rest using the X, without them rebuilding.
Link.
