Eduardo Rolon
Column Core Line uneditable in AC12 -build 2523
If you decide to place a Column the setting for the Core Line Pen (color and line type) can not be edited until you select the Custom profile option and uncheck "Apply Structure Settings".
Is there a reason why the settings for Custom affect the Rectangular and Circular Options?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
19 Replies 19
Eduardo Rolon
Selecting the Custom Profile Option, the only place to edit this option.
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
Now it is editable.
AC29 US/INT -> AC08
another Moderator
David Maudlin
Eduardo:
I don't know how you got this behavior, I cannot reproduce it.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Eduardo Rolon
David,
I just tried to reproduce it and I can't. I originally saw this behavior in the computers of one of my students and then I was able to duplicate it on my machine. Curiouser…
Could have been a library issue?
AC29 US/INT -> AC08
another Moderator
David Maudlin
ejrolon:
I don't see how the libraries would affect a tool that does not use library parts, I would be more suspicious of a Complex Profile. Or maybe the computer just hiccuped.
Eduardo Rolon
David,
I agree that the library should not be the culprit but the reason I listed it was that that is what changed after I took the screen shots. Before the update I was able to duplicate the problem.
The hiccup occurred in two different comps, one windows one mac, both using the same template file for the project. So your theory of a complex profile being the real culprit sounds more reasonable. I'll see if I can get the error again at the University Lab.
AC29 US/INT -> AC08
another Moderator
I encounter this every time I use the GRID SYSTEM TOOL.
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Eduardo,
This was a bug in the US template, which was corrected in the build 2420 Hotfix#3. (The most recent Hotfix is #4, build 2523). Your student's ArchiCAD was probably not up-to-date.
Greg
Gergely Kmethy
Eduardo Rolon
Greg,
That makes more sense.
Thanks
AC29 US/INT -> AC08
another Moderator
