2007-10-10
02:52 AM
2023-05-26
12:52 PM
Rubia Torres
2007-10-11 01:14 PM
2007-10-12 02:33 AM
2007-10-13 12:17 AM
2007-10-17 11:49 AM
2007-10-17 04:58 PM
fuzzytnth3 wrote:The Grid Tool never did work right in AC10, and is down-right broken in AC11. The "Length" parameter you refer to is the length of the grid line. The height above FFL is set in the Marker dialog, although this is unpredictable see this link.
Did these problems also happen in AC 10 as well? Reason I ask is that I am working on a AC 10 project which has 2d Grid Lines but as the Project is moving on I want the Sections to show the Grid and so I was considering replacing the 2d Grid with a Grid Tool Grid if you know what I mean.
One other question - in the Grid Tool object there is a parameter to set the "Length" under 3d Geometry I think they mean height in fact but no matter what I try to set it to the top most point of the Grid Line in the Section window is always 6.0m above the FFL. Is there anyway of getting some control of this?
TIA
2008-01-19 03:56 PM
