Columns and walls clean intersections
Hi everybody, its possible to turn off cleaning intersection between columns and walls ? I need two different visualization configurations in the same project. One with columns and another one without columns. But when i turn off columns layer, a hole appears in walls. Thanks !
Eduardo Rolon
Change the layer number for the columns to a different one for that layer set.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
Dontknow
Change the 'Layer Intersection numbers' from your layers of your columns and walls.
For example both on 0 or columns on 1 and walls on 2.
More info here.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
