2017-03-1805:07 AM - last edited on 2023-05-2602:09 PM by Rubia Torres
2017-03-1805:07 AM
Hi guys i was wondering if anyone knows about the columns settings? i have tried to set my UB to 305x102x22mm but it wont let me, neither in the custom settings. I got the S.E.D from a engineering table stating the correct sizes for the correct height, weight, angle, and spans. Any help much appreciated thankyou
so basically what i am saying is that i cant create my steel columns to my desired dimension. i have tried with universal beams and custom beams but to no avail any help will be awesome
You can import standard steel sizes. In AC19 go to Options > Import standard steel profiles and select New Zilland in the country code. Select the profiles and sizes you want and "Add profile to the project". In AC20 its Options> Complex Profiles > Import... Use these with Complex Profile beams.
For future reference add your AC version and OS (Mac or Windows) to signature in your forum profile (link at top of forum page) as answers can vary depending on your setup.
