Combining 2 of the same elements into a single element
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-11-18
08:19 PM
‎2023-05-25
05:40 PM
Rubia Torres
‎2013-11-18
08:19 PM
Regards.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-18 08:36 PM
‎2013-11-18
08:36 PM
There is no Merge, as such, but you can use the pet palette "Add" button - select the first slab, click on an edge to bring the pet palette up, click on the "Add" button, magic wand (hold down space bar) the 2nd slab edge and it will add that 2nd shape. The original 2nd slab will remain though, so delete it once you have finished.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-19 08:23 PM
‎2013-11-19
08:23 PM
Thanks for the tip Stuart but unfortunately it does not seem to work. It seems that when I do as you indicated it does add the 2 slabs together but it only adds the perimeter of the slab and does not add the openings in the slab that is being added. In my case there are openings in both slabs for stairs and other such things. Also, it didn't matter which order I selected the 2 slabs. Either way the openings in the second slab don't get added. The reason for wanting to merge or add the 2 slabs is that I don't want to have to recreate the openings. Any other ideas.
Regards.
Regards.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-11-19 08:32 PM
‎2013-11-19
08:32 PM
You are correct, the openings will have to be re-created, but using the magic wand this should not take long.
Also, if you have the Quick Layers palette on, select your slabs, hit the "Hide all others" button on Quick Layers (and all other layers will turn off) to make it real easy to perform your magic wanding. Hit the quick layers Undo button when complete to revert to previous layer state.
