Streamline your workflows and master BIM coordination! Program starts April 28.!
Complex Profile Column intersection with walls
Maged Ibrahim
we created a U Shape column for a lift well. Part of this column will cover a wall on the plan. The column should cut the wall since they are the same group intersection, but when we turn the model view option to be no fill for construction elements the wall appear under the column as you can see in the attached screen shot. The U shape column should cover the wall as the other column did but it does not happen. Any suggestion?
Djordje
Maged, good to see you
I have a question: why are you using a column for the lift well? Is a wall not better?
The columns should intersect the walls, therefore the part of the wall where the column intersects should be eaten out, maybe?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Maged Ibrahim
Nice to hear from you also Djordje
yes but the point is the Complex Profile column does not eat the wall
Ingolf
I am not quite sure if I have understood your problem. May I suggest a solution that is very simple? Choose the wall that shall be hidden. Use the Display Order (by right click) and choose Send to Back. In this way the wall will (hopefully) be presented under the Lift Well in the Plan.
undefined
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
