Problem with Composite structures
Hi
When I try to edit the selected item in the Composite structures dialogue box I click on the drop down arrow and the menu opens and then instantly closes and I cant make any changes to the structures.
Don't know if this is a bug or Some setting on my PC is preventing it from showing. So far I haven't had this problem with any of the other menus.
Please help
2 REPLIES 2
Ingolf
It may be problems in your ArchiCAD file. Personally I prefer to make use of the Merge function in ArchiCAD. Open a NEW unused ArchiCAD file. Choose File - File Special -Merge in the NEW file and then choose the problem file. This is to to "adjust" the problem file. (From one of my books on ArchiCAD)
Good luck!
Ingolf Sundfør, Bricklayer, Author of several Real Life Problem Solving Books for Archicaddicts in Norway.
PC/i7/W11/ArchiCAD 6.5-27
Djordje
It is even better to merge into a blank started from your template file, as all the settings should be as they are ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
