Complex Profile Modifier Issue
With the new modifiers to complex profiles, is it possible to anchor the start/end to another material edge? A bit hard to explain. See image below
Basically I'm trying to have the "Start" of the skirting be dependant and begin where the "end" of the plasterboard is. From what I understand, what I have should work. The circle nodes are anchored to the correct material corner.
What I'm getting instead is this:
Am I missing something or is this not yet possible? The brick veneer examples only had heights to play around with.
The end goal right now (if the above works) is to have a single wall profile for external and internal with all the skirtings, tiles, etc to both reduce the drafting needed to extract quantities and using the favourites to control and turn "on/off" the elements by reducing the thicknesses to 0.
Any help would be appreciated, thank you
11 Replies 11
James B
Andrew wrote:
Thanks for all your help.
You're welcome, glad it worked out
James Badcock
this helped me so much. thank you guys!
