Complex Profile errors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-12-13
08:03 PM
‎2023-05-23
04:39 PM
Rubia Torres
We have a project that, when opened, applies the complex profile from a different project in place of the complex profile the project is supposed to be using. For instance, what should be crown molding in this project is using a profile we created in another project for a slatted fence.
This can happen with either one project open or both. They are both from the BIM server.
We created a new profile for the one that was using the wrong profile in case there was some sort of UID issue. Now the project opens with that profile using a different incorrect profile, instead of slatted fence, it now uses a metal panel complex profile we created in the other project.
To fix it is simple, just select the object, go to settings and hit 'OK' and it switches back to the correct complex profile.
How can this be avoided? It's simple to fix each time, but it does cause problems if it isn't done before printing a set.
Thanks,
Mike
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-12-15 12:14 AM
AC24
iMac Pro (2017) - macOS 10.14.6- 3.2GHz Intel Xeon W - 32GB RAM - Radeon Pro Vega 56 8GB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-04 12:01 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-04 05:19 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-05 07:26 PM
GS, Please fix this ASAP for us, please!
Windows 10 x64
Since ArchiCAD 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-18 04:42 PM
We have found the cause of this problem and the solution to it. ArchiCAD 15 Hotfix-3 will contain the fix for it. Unfortunately putting this fix into Hotfix-2 (due in February) would delay the hotfix too much. Nevertheless we are going to contact those of you who were struggling with this problem very soon for giving you a custom solution in relation to the bug.
Sorry for the inconveniences caused so far.
Best regards,
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-18 09:05 PM
Good to know selecting, going to settings and clicking okay will work.
VERY happy to know that a solution is coming. I never like these kind of glitches.
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-23 06:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-02-13 10:27 PM
That seems to have corrected it for us. We have this (or similar) issue with our CPs on one Teamwork project. I should add that it didn't correct it permanently - just for the time being. But it seems to be the easiest correction while possibly not the quickest.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-02-14 12:56 AM
Best regards!
Technical Support Team - GRAPHISOFT North America
Tutorials
GRAPHISOFT Help Center
