ā2007-09-12 09:37 AM
ā2007-09-12 02:33 PM
Rod wrote:are your walls set to use the composites' skin priorities (look under wall settings/floor plan and section/structure/ wall priority)
A search with topic results in nil![]()
Therefore has anyone been able to achieve a
clean wall intersection with Complex Wall Profiles
where the wall structure in one of the walls has
different elements/fills assigned.
Please see attached.
ā2007-09-13 01:37 AM
xristina wrote:Thanks Christina, yes wall priorites are enabled.
are your walls set to use the composites' skin priorities /.......
ā2007-09-13 03:45 AM
ā2007-09-13 04:36 AM
Rob wrote:Rob, I have another complex wall which cleans up correctly.
/....So in other words the fill type has a priority over priorities number./...
