‎2013-03-12
09:16 AM
‎2023-05-24
12:49 PM
Rubia Torres
‎2013-03-12 09:19 AM
‎2013-03-12 11:22 AM
‎2013-03-12 11:51 AM
‎2013-03-12 12:09 PM
‎2013-03-13 12:21 PM
Complex profile #1 is the basic shape profile defined by panes using the magic wand set to fixed lengths. On the section, place muntins at pane edges.I assume you mean the profile on the right side of the image, which is perfect. and I did that but the problem is that on in elevation the building is changing its size (not the section) the building changes its width . the curve of the plans using the same center but different radius. I can't use one section profile for the all the floors because if it matches the lower floor edge (elevation) it will only cover portion of the elevation on upper floors which are wider, and I will end up with empty space on the sides. using Morph or shell is not avoidable, specially because I need this envelope to be reflected in plans in order to work on plans, other wise I would have used solid element operation with profiled walls .
‎2013-03-13 06:33 PM
‎2013-03-14 12:17 AM
‎2013-03-14 11:13 AM
‎2013-03-15 08:01 AM
