Anatatj
Complex profile lineweight problem
I have problem with lineweight of complex profiles on floor plans.
The lineweights look correct in the profile manager and in section but not in floor plan. I tried to set draw order but its not helping.
True lineweight is on. Any advice? I attached screenshots.
1 Solution
Miha Nahtigal
In profile editor select your insulation fill. From there you can click on the fill's line facing brick. A popup appears, click the "Custom Edge Settings" button and turn the line off by unchecking "Show Cut Line".
That should do the trick.
BIMquants - Free Plugin for Quantities and Costs Estimation in Archicad | BIMrender - Free & Open Source Plugin for AI rendering in Archicad
Go to post
2 Replies 2
Miha Nahtigal
Anatatj
That worked, thank you!
