You could draw half of the tapered profile and if it is squared, draw four sides.
Or just use the tapered wall options, that might be quicker.
Regarding profiled columns/beams: if you think in steel profiles, it makes more sense
😉 You are just extruding a shape along a path.
You could even taper the edges of a square slab or roof. Or use the Mesh tool to elevate the tapered top.
Try to think of the design tools as that, rather than the elements they show. A low Wall can also be a concrete beam, a profiled Beam can be a detailed roof gutter, a frameless Curtain Wall can be interior glazing wall system, etc etc
Just remember that if you are going full BIM: slap on the proper IFC tag before sharing the model with another party.
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
