Once again I get 2/3 of the way through working things out to make sure we have standard methodes for version 14 that work and i find things that don't work. When doors are placed into walls using complex profiles they do not the room number information from the zones when you change the partial structure display to without finishes or core only. Composite walls work correctly. Has anyone else run into this. It makes it very hard to work with door tags and schedules. I hope they fixed it in 15, but I'm not holding my breath.
