Compoite wall Intersection 13 - skin does not cut
Why
I tried many priorities
7 Replies 7
Your centre skin has a priority of 0 and the gypsum is 10.
So the centre skin can't punch through the outer ones.
You need a priority higher than 10 and it should work fine - for this particulsr situation at least.
Rod Jurich
Adalbert wrote:
Why
Albert, take a look here
and here, best explanation yet by Cecilia.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Tank you for the help
I tried figure A and does not work
Erika Epstein
Adalbert,
Have you checked that the walls have skin priorities enabled?
Select the walls,
Floor Plan and Section>Structure> Enable Skin Priorities
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Yes I do not have problems with all the wall just this one. I will create new walls maybe that will solve the now that I understood the logic
New walls will cut old ones refuse to cut.
I have replaced them and cleared the old ones.
Tnaks for all the help.
I have seen this problem not long ago on AC12.
It drove me crazy.
I did the same thing: delete the affected Walls, create new ones which did the cut. I have no idea of the reason.
