Keith,
Are you sure the skin separator line is checked in that composite?
I just duplicated a wall that has 2 skins with the same fill and turned the separator line off.
It looks in plan like the fills have merged.
But oddly when I explode them it creates the separate fills (both the same type) and adds in its own separator line but it has no pen number.
I just noticed you are version 14 on Mac.
I just tried in 15 on Windows.
I will try 14 in a few moments.
David wrote:
I sometimes use this feature if I have a lot of fills on the floorplan which I want to merge into one.
select them all, cut and paste into a new complex profile, save it and open again select THE fill (its now one body) and paste back to the floor plan. Only worth doing with a lot of fills.
Hope this helps
David,
Have you tried the fill consolidation tool?
Much easier.
