Brad Elliott
Confused Library parts
We have multiple computers working on files and all using library's loaded off the server. So everyone is using the exact same library. Sometimes on only one computer the office the library parts load as the wrong ones. IE The toilet part loads as a sofa part. The grid part as a car, etc. If you open the part it is the right name but the object is wrong. Usually closing the file and reopening it works to fix it but it is an unusual annoyance. Any Ideas? The file is in 8.1.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
3 Replies 3
Red
Where I work we also load off the server, and have never ran across this problem. Maybe you should uninstall/reinstall AC on that machine..
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
Try deleting the ArchiCADGdlBinCode.dat file in the Home/Library/Caches/Graphisoft/ArchiCAD Cache Folder/AC 8.1.0 v2 or AC 9.0.0 USA v1 folder (depends what you use). Maybe you have a corrupt cache of the libraries.
If you are using satelite library, clear that too. (If you have seleceted to 'use a local copy (satellite)' in Library Manager/Library Cache Settings
Gergely Kmethy
Brad Elliott
Thanks for the suggestion. We tried that and it didn't work. We aren't using the Satellite library.
M1 Macbook Pro
