ā2003-11-18 03:46 PM
ā2003-11-20 05:29 PM
rocorona wrote:This shortcut is still there, it just doesn't have a key assigned to it by default. It's under the Actions list in keyboard shortcuts (see attachment). I've got mine assigned to the ` or ~ key at the top left of my keyboard for quick access, although I must admit I'm still getting used to it.
Now the tools can be activated with keyboard shortcuts, but I miss the "back to previous tool" function that was provided by the right arrow.
ā2003-11-20 05:36 PM
Lee wrote:You need a modifier key for the Menu Command shortcuts, but not for the Actions or Tools shortcuts. Take a look at the default ArchiCAD 8.1 scheme from the pull down list, it has many functions using letters only. Did you start from this scheme? Are you sure your not applying the same key to two functions?
...but I've discovered that only numbers, punctuation mark and symbol keys work without a "modificator" key. Assigning a letter key by itself doesn't seem to do anything. Am I missing a setting, or is my keyboard not set up right?
ā2003-11-20 06:02 PM
ā2003-12-16 01:44 AM
ā2003-12-16 03:38 AM
Richard wrote:... also try to switch the 2D OpenGL off, or tweak the settings?
For the filled-in "o", try different settings under Preferences, 2D Redraw options to see which works the best. HTH,
