‎2020-04-12
04:58 AM
‎2023-05-09
03:53 PM
Rubia Torres
Solved! Go to Solution.
‎2020-04-14 04:18 AM
‎2020-04-13 01:05 AM
‎2020-04-16 11:44 AM
Barry wrote:And thank you Barry Kelly for this explanation, I will consider to use this in case I have special shapes that I need to import as objects! Thank you!
You can use 'classifications' to classify any element as anything you like.
So then when saved as an IFC file, the object will be classified as a column.
But within Archicad it will still be an object (with a column classification).
