Convert external object into Beam, Column, Wall
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2020-04-12
04:58 AM
‎2023-05-09
03:53 PM
Rubia Torres
‎2020-04-12
04:58 AM
I've tried to search on the forum and in general but I couldn't find a complete and successful answer. I have some 3D models that I created with Rhino5, and for this reasons all the elements, when imported, are considered as Objects.
My question is very simple: is there a procedure or a way to "tell" ArchiCad to consider an object as a specific architectural element in ArchiCad? For example if I select the extrusion of a column (created with Rhino), can I convert it into the element "Column" in the software?
If not, is there any way (maybe an external plugin/add-in) to manage this?
Thanks in advance, and have a nice time!
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-14 04:18 AM
‎2020-04-14
04:18 AM
You can use 'classifications' to classify any element as anything you like.
So then when saved as an IFC file, the object will be classified as a column.
But within Archicad it will still be an object (with a column classification).
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-13 01:05 AM
‎2020-04-13
01:05 AM
any thing imported is considered as an object, you can't create a column from an object, place it as it is, or convert it to morph for further editing
Archicad 27
Windows 11 professional
Archicad 27
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-14
04:18 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2020-04-16 11:44 AM
‎2020-04-16
11:44 AM
Thank you both for your kind replies
Barry wrote:And thank you Barry Kelly for this explanation, I will consider to use this in case I have special shapes that I need to import as objects! Thank you!
