Convert external object into Beam, Column, Wall
Hello everyone,
I've tried to search on the forum and in general but I couldn't find a complete and successful answer. I have some 3D models that I created with Rhino5, and for this reasons all the elements, when imported, are considered as Objects.
My question is very simple: is there a procedure or a way to "tell" ArchiCad to consider an object as a specific architectural element in ArchiCad? For example if I select the extrusion of a column (created with Rhino), can I convert it into the element "Column" in the software?
If not, is there any way (maybe an external plugin/add-in) to manage this?
Thanks in advance, and have a nice time!
1 Solution
You can use 'classifications' to classify any element as anything you like.
So then when saved as an IFC file, the object will be classified as a column.
But within Archicad it will still be an object (with a column classification).
Go to post
3 Replies 3
Ahmed_K
Mentor
any thing imported is considered as an object, you can't create a column from an object, place it as it is, or convert it to morph for further editing
Archicad 27
Windows 11 professional
Thank you both for your kind replies
And thank you Barry Kelly for this explanation, I will consider to use this in case I have special shapes that I need to import as objects! Thank you!
