Cool Excel
now this would be neat if we could get this to work in AC...
http://www.cadig.com/
10 REPLIES 10
__archiben
it's not live, but you can use the excel camera tool to do much the same thing . . .
paste in as 'drawing elements' and all is good . . .
~/archiben
b e n _ f r o s t
problem we have ran into with pasting and live linking is that only allows 45 rows...it's very limited...where is the excel camera tool.....
__archiben
i've no idea where it's originally found, but i've put it out in my toolbar for easy access . . .
just select the cells you want to 'copy' and then click the camera tool. in archiCAD (or more typically a layout) 'paste' and choose 'as drawing elements'. the text comes in as text and any cell borders are retained as lines.
as i said - it's not live, but it's a pretty quick and easy way of grabbing a chunk of excel data and placing - wysiwyg - in a layout book. especially for non-OLE mac users!
~/archiben
b e n _ f r o s t
For Windows users just Highlight area Ctrl-C (Copy) in Excel. Go to PlotMaker, Ctrl-V (Paste). Paste as OLE. This will be live, and Excel sheet can be opened in PM by double clicking the embedded OLE object.
Chazz
archiben, this is the identical behavior I see with a simple copy paste between AC/PM. Any advantage that I'm missing?
Nattering nabob of negativism
Yes I have been using CTRL C (copy) and I have tried OLE.....but for what ever reasons I get cut off at the 45-50 rows....any clues....
Just did a quick test and I was able to OLE a Sheet with 83 Rows (row Height set to 15).
I am back on MS Excel 97 SR-2.
Haneef Tayob
Posted something in Jan 13 2005 where I mentioned how I was pasting 'live' drawing lists from Excel into Plotmaker. There are some issues around it but when it works, it works like a dream.
under construction documentation:
archicad-talk.graphisoft.com/viewtopic.php?p=29170&highlight=excel&sid=a95788d9f1678972b544e5ab83917...
another recent tread also under Construction Documentation you can follow is:
archicad-talk.graphisoft.com/viewtopic.php?p=53770&highlight=excel#53770
it covers size of objects one can paste, etc.
I've even pasted successfully from OpenOffice.
regards
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
I gave it a run in Plotmaker to Excel...and only get 45 rows....just to let you know...I am using 2003....anyone using 03 give it a try for me and see if you get the same results
