Copy 'custom settings' window
Dontknow
Is there a way to copy your 'custom settings' from a window to another shape of window like colors, the sill, the board, wall closure, reveal type and depth?
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
4 REPLIES 4
Eduardo Rolon
1. use the eyedropper to pick the settings from the window
2. Open the window settings but do not click on any window
3. Navigate to de desire window that you want to apply the settings and use the syringe tool to inject them before selecting. This should copy the common settings between the two windows.
http://helpcenter.graphisoft.com/tips/how-to-change-door-window-and-object-types-while-keeping-their...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Thank you so much!!! This is such a great short cut and will save me so much time!
Dontknow
From me to! Thnx!
ArchiCAD 25.
That is such a helpful tip.
Every time I pop in to the Forum I learn something valuable !!
Thank you.
