2005-02-18 12:56 AM
2005-02-18 05:50 PM
2005-02-18 07:08 PM
2005-02-18 07:17 PM
Hielke wrote:You're absolutely right. However the main problem I have with this solution is, what happens at the other ends of the walls? You change the reference lines here and at the other end of the wall there's another wall made up of other components and that intersection doesn't clean up.
There is no need to patch for the intersection to clean up.
Just put the reference line of the walls as shown by the arrows in the attached picture.
I have never encountered any problems this way. Just remember the reference lines have to connect.
2005-02-18 07:30 PM
2005-02-18 08:18 PM
Link wrote:
And you're sure turning the wall end off won't solve all your problems right?
2005-02-18 08:28 PM
2005-02-18 08:50 PM
Link wrote:
Wall end visibility works a lot of the time. That's why it's there right? And conscientious reference line placement is also key to have walls heal properly
2005-02-22 03:44 AM
Barry wrote:As far as I can tell, it doesnt just move the reference line, it flips the whole wall... which is about as usefull as uhm.... something not very usefull...Nefarious wrote:It's already there.
I wish there was a feature to "Flip" the wall... So the wall stays in the same place, but the reference side moves.....
In the TOOLS menu > MODIFY WALL > REFERENCE LINE
2005-02-22 03:48 AM
2005-02-22 03:58 AM
