Corner Window will tilted wall
Hey Guys,
i'm try to put the corner window into a corner where a straight wall meet the tilted wall. I'll thought is will be simple for Archicad since they introduce tilted wall long time ago and allowed window to associated will wall. But apparently not corner window. Anyone got any idea how to do it?
I know there is several wall to do it like draw your own custom object library or using wall, slab tool to model the window up. But i'm looking for an Archicad window that can do that. Anyone?
rocorona
also WALL END elements don't play well with tilted walls. Specially those with double slant.
I think for you the simplest way is to cut away the unwanted piece with a boolean subtraction (use a Morph or something else)
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
Csaba Kezer
Dear Talkers,
Thank you for your comments.
Currently the Corner-Window tool works only with straight walls. I understand that placing a Corner Window into slanted walls can be useful feature and therefore I added a request about it to our wishlist.
It is noted also, that not all Wall Ends are working properly with Slanted or Double Slanted wall types. I have registered it also to the wishlist.
Best regards,
Csaba Kézér
Director, Global Customer Support
..maybe using a trapezoidal shape window on the second wall could do the trick, but if you are looking to have a frameless corner, that wouldn't work I guess. I'm having similar issues even with straight walls.
