Correct display of roofs
See attached. I have two roofs, a main and a side roof. The side roof is overframed onto the main roof, but a piece of it goes under the main roof. I want this to show correctly in plan. If I adjust the display order, it either shows the entire side roof above the main, or it hides it below.
I posted this a while ago, but I can't seem to make the old method work. http://archicad-talk.graphisoft.com/viewtopic.php?t=38191&highlight=
13 REPLIES 13
3D view
You may be looking for a 3D document approach, as demonstrated here: https://www.youtube.com/watch?v=5hVsyCu6vFw
Richard
AC26 (since AC6.0), Win10
I need this to show accurately on all my floor plans. I don't think a 3D document will work here.
Zoltan Fuchs
Hi Steven, maybe this will works:
1. Select the two roof planes
2. Right mouse click>Connect>Merge Elements
i7-4770K / 16GB / GTX560 2GB / 512GB SSD / Win10 64bit
AC21 (HUN-64 bit) / Bimx Pro / Revit 2017
Zoltan,
Unfortunately, no.
David Maudlin
Steven:
Here are two options. First select the over-framed roof, right-click and select Connect > Trim Elements to Roof/Shell, click the main roof, and then click on the part of the over-framed roof you want to remain. The main roof will cut away the over-framed roof. Then:
1. For the main roof, Roof Settings > Model > Trimming Body > Pivot Lines down (rather than Contours down) will trim the over-framed roof at the Pivot Line, not the edge. This will work if the Pivot Line is where the over-framed roof needs to end.
2. If adjusting the Pivot Line creates problems elsewhere in the model, then add another over-framed roof piece under the main roof, select the 2 over-framed roofs, right-click > Connect > Merge Elements.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thanks for the reply. I tried it but it's still not working. I understand how to trim the roof, but my problem is I want it to look correct in 2D view on floor plans. This is what it still looks like after trying your method.
This is how I want it to look, with the portion of the side roof that is under the main roof hidden by the main roof.
Maybe this can't be done? As a workaround, I could use 2D fills and lines to make it happen.
