Create a high number of composite Structures at once
Good Day,
Is there anyway I can create a number (like 10 or 20 or more) composite structures with different number of skins, thickness and material at once?
Larissa
Szabolcs Miko
Hi Larissa,
I'm not sure what you mean, but there are two ways to create composite structures:
Use the Composite attributes:
https://helpcenter.graphisoft.com/user-guide/77393/
Use complex profiles:
https://helpcenter.graphisoft.com/user-guide/76459/
I hope this is what you're looking for.
Szabolcs Mikó
Education Program Manager
I'm confronted with the task of creating a catalog of hundred of walls. They have around 30+ different composite structures and I'm searching for the easiest and fasted method to create them.
Larissa,
You could create a single composite structure export that to XML, examine the XML data structure and edit / create a library of composites as XML or o would simply just create the composites within ARCHICAD, 30 composites would take no longer than and hour to set up
Scott
