Create a high number of composite Structures at once
Good Day,
Is there anyway I can create a number (like 10 or 20 or more) composite structures with different number of skins, thickness and material at once?
Larissa
3 Replies 3
Szabolcs Miko
Hi Larissa,
I'm not sure what you mean, but there are two ways to create composite structures:
Use the Composite attributes:
https://helpcenter.graphisoft.com/user-guide/77393/
Use complex profiles:
https://helpcenter.graphisoft.com/user-guide/76459/
I hope this is what you're looking for.
Szabolcs Mikó
Manager, Customer Support
I'm confronted with the task of creating a catalog of hundred of walls. They have around 30+ different composite structures and I'm searching for the easiest and fasted method to create them.
Larissa,
You could create a single composite structure export that to XML, examine the XML data structure and edit / create a library of composites as XML or o would simply just create the composites within ARCHICAD, 30 composites would take no longer than and hour to set up
Scott
